Help
Kyocera Rise Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Needs More Images
Needs More Images
A few more images would make this guide's procedures crystal clear.
Member-Contributed Guide
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
Step 1 Kyocera Rise Teardown  ¶
Teardown of Kyocera Rise Teardown of Kyocera Rise
  • Teardown of Kyocera Rise
Step 2 Removing the Battery  ¶
First remove the back cover to expose the battery Next pull the battery from the phone
  • First remove the back cover to expose the battery
  • Next pull the battery from the phone
Step 3 Removing White Sticker  ¶
Remove the white sticker to expose the black plastic tab that is covering the ZIF connector that is connecting the flex cable that goes between the motherboard and screen Remove the white sticker to expose the black plastic tab that is covering the ZIF connector that is connecting the flex cable that goes between the motherboard and screen
  • Remove the white sticker to expose the black plastic tab that is covering the ZIF connector that is connecting the flex cable that goes between the motherboard and screen
Step 4 Peeling Away Black Tab  ¶
Remove the black tab by first getting under it with something sharp like an exact knife It's adhered with a weak adhesive and peels away easily As you can see a hole was left open to specifically allow quick and easy mate/unmate of the ZIF connector
  • Remove the black tab by first getting under it with something sharp like an exact knife
  • It's adhered with a weak adhesive and peels away easily
  • As you can see a hole was left open to specifically allow quick and easy mate/unmate of the ZIF connector
Step 5 Removing Screws  ¶
Remove all six screws using a Phillips # 0 (PH0) screwdriver Remove all six screws using a Phillips # 0 (PH0) screwdriver
  • Remove all six screws using a Phillips # 0 (PH0) screwdriver
Step 6 Disconnecting ZIF  ¶
Unplug the ZIF (zero insertion force connector) by running a pair of blunt Tweezers underneath it. Twist and pull, this causes the black latch that's holding down the flex cable to open and then the flex cable can be pulled out of the ZIF with the Tweezers. Since the screws were removed the phone's keyboard containing half can be lifted away from the screen. Since the screws were removed the phone's keyboard containing half can be lifted away from the screen.
  • Unplug the ZIF (zero insertion force connector) by running a pair of blunt Tweezers underneath it. Twist and pull, this causes the black latch that's holding down the flex cable to open and then the flex cable can be pulled out of the ZIF with the Tweezers.
  • Since the screws were removed the phone's keyboard containing half can be lifted away from the screen.
Step 7 Peeling Away The Keyboard  ¶
Turn the phone so that the keyboard is facing you The keyboard is flexible and can be peeled away from the body of the phone The keyboard is latched in about 6 places and can peeled away slowly and carefully. It is not held down with adhesive.
  • Turn the phone so that the keyboard is facing you
  • The keyboard is flexible and can be peeled away from the body of the phone
  • The keyboard is latched in about 6 places and can peeled away slowly and carefully. It is not held down with adhesive.
Step 8 Removing the Motherboard  ¶
Remove the 3 screws again using the Philips #0 screwdriver.  This will allow you to pull out the motherboard from the back housing Remove the 3 screws again using the Philips #0 screwdriver.  This will allow you to pull out the motherboard from the back housing Remove the 3 screws again using the Philips #0 screwdriver.  This will allow you to pull out the motherboard from the back housing
  • Remove the 3 screws again using the Philips #0 screwdriver. This will allow you to pull out the motherboard from the back housing
Step 9 Motherboard and Chips  ¶
The metal shielding was difficult to unscrew and the screws were all stripped in the process. Using a needle nose plier, the metal shielding was torn away The exposed motherboard is shown here along with microscope pictures of the chips. Chip #1
  • The metal shielding was difficult to unscrew and the screws were all stripped in the process. Using a needle nose plier, the metal shielding was torn away
  • The exposed motherboard is shown here along with microscope pictures of the chips.
  • Chip #1
  • Chip #2: 1 GHz Qualcomm processor PM8058
Step 10 Motherboard and Chips  ¶
Chip #3: Qualcomm CDMA antenna driver QTR8615 Chip #4: Samsung 2 GBit memory Chips #5
  • Chip #3: Qualcomm CDMA antenna driver QTR8615
  • Chip #4: Samsung 2 GBit memory
  • Chips #5
Step 11 Removing Antenna Assembly  ¶
After removing the motherboard the back housing can then be disassembled.  The volume rocker and the power button slide out of the back housing without any effort The upper antenna assembly is held in place only through a "snap into place" mechanism.  It can be removed by apply a little prying pressure with end of a tweezer at the locations indicated with arrows The upper antenna assembly is held in place only through a "snap into place" mechanism.  It can be removed by apply a little prying pressure with end of a tweezer at the locations indicated with arrows
  • After removing the motherboard the back housing can then be disassembled. The volume rocker and the power button slide out of the back housing without any effort
  • The upper antenna assembly is held in place only through a "snap into place" mechanism. It can be removed by apply a little prying pressure with end of a tweezer at the locations indicated with arrows
Step 12 Lower Antenna Assembly  ¶
The lower antenna assembly can be similarly removed by applying a little pressure to pop it out of the assembly
  • The lower antenna assembly can be similarly removed by applying a little pressure to pop it out of the assembly
Step 13 Antennas and Housing  ¶
Both sides of the back assembly and antenna assemblies are shown here Both sides of the back assembly and antenna assemblies are shown here
  • Both sides of the back assembly and antenna assemblies are shown here
