Help
MacBook Pro 15" Unibody Mid 2009 Battery Replacement
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
  • Author: Walter Galan
  • Time estimate: 15 - 30 minutes
  • Difficulty: Moderate
Use this guide to replace an aging battery. If your battery is swollen, take appropriate precautions.
Step 1 Battery  ¶
Remove the two 5-Point Pentalobe screws along the top edge of the battery.
Step 1 Battery  ¶
  • Remove the two 5-Point Pentalobe screws along the top edge of the battery.
  • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
Step 2  ¶
Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove third five-point Pentalobe screw hidden underneath.
Step 2  ¶
  • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove third five-point Pentalobe screw hidden underneath.
Step 3  ¶
Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case. Do not try to completely remove the battery just yet.
Step 3  ¶
  • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
  • Do not try to completely remove the battery just yet.
Step 4  ¶
Tilt the battery back enough to access the battery cable connector.
Step 4  ¶
  • Tilt the battery back enough to access the battery cable connector.
  • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
  • If you're installing a new battery, you should calibrate it after installation.
