Help
Replacing 1995-1999 Dodge Neon Spark Plugs
Needs More Images
Needs More Images
A few more images would make this guide's procedures crystal clear.
Member-Contributed Guide
This is a walk through of how to replace the spark plugs in a Dodge Neon. This demonstration is on a 1998 model.
  • Author: Benjamin
  • Time estimate: 30 - 45 minutes
  • Difficulty: Easy
Step 1 Spark Plugs  ¶
The air vent is covering 4 spark plugs.
  • The air vent is covering 4 spark plugs.
  • Twist off the wing nut on the left (see hand in photo).
  • The big plastic art with the "SO??" marked on it just lifts up and out
  • It sounds like you are breaking something but you are just disconnecting it from the air filter housing.
Step 2  ¶
Image of engine with out plastic cover that was removed in step 1. See the air filter exposed in the back?
Step 2  ¶
  • Image of engine with out plastic cover that was removed in step 1. See the air filter exposed in the back?
  • There are numbers on the top of the engine with wires going to the four spark plugs in the front of the engine (between the oil dipstick and the oil repository).
  • Start with s
