Help
MacBook Air 13" Mid 2013 Fan Replacement
Replace the Fan in your MacBook Air 13" Mid 2013.
Use this guide to replace the fan.
Step 1 Fan  ¶
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Step 1 Fan  ¶
  • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
Step 2  ¶
Peel the rubber gasket off the adhesive on the top of the fan.
Step 2  ¶
  • Peel the rubber gasket off the adhesive on the top of the fan.
Step 3  ¶
Remove the following three screws securing the fan to the upper case:
Step 3  ¶
  • Remove the following three screws securing the fan to the upper case:
  • One 3.6 mm T5 Torx screw
  • One 2.7 mm T5 Torx screw
  • One 3.6 mm T5 Torx screw with a short head
Step 4  ¶
Lift the fan from the I/O board side and pull it free from the upper case. Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
Step 4  ¶
  • Lift the fan from the I/O board side and pull it free from the upper case.
  • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
