Help
Garmin Nüvi 370 LCD Display Replacement
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Slice and Dice
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
This step by step guide will show you how to dissemble your Garmin Nüvi 370 in order to access and replace the LCD display.
In this guide the repairer replaces the LCD display of the device by carefully prying apart the components with one's hands.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • None
Estimated Duration: 5 minutes
Step 1 LCD Display  ¶
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
Step 2  ¶
Hold the front panel plastic and screen as shown.
Step 2  ¶
  • Hold the front panel plastic and screen as shown.
  • Gently apply pressure on the left and top left corner to allow the screen to come out of the plastic shell.
Step 3  ¶
Once the top-left corner is out, carefully start detaching the bottom of the screen, starting from the bottom left.
Step 3  ¶
  • Once the top-left corner is out, carefully start detaching the bottom of the screen, starting from the bottom left.
Step 4  ¶
Finally, gently pull the screen out of the right side of the plastic shell.
Step 4  ¶
  • Finally, gently pull the screen out of the right side of the plastic shell.
Step 5  ¶
The screen should now be completely detached.
Step 5  ¶
  • The screen should now be completely detached.
  • Insert new, functional display screen.
