Help
Philips DC320 37 Speaker Replacement
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
This guide outlines how to remove and install the speaker for the Philips DC320/37.
  • Author: Graham Rolph
  • Time estimate: 20 minutes
  • Difficulty: Easy
Follow the procedure outlined in this guide to remove and install a speaker.
Step 1 Speaker  ¶
Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
Step 1 Speaker  ¶
  • Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
Step 2  ¶
Slide the back panel towards top of the device and lift away from the device to detach back panel. Slide the back panel towards top of the device and lift away from the device to detach back panel. Slide the back panel towards top of the device and lift away from the device to detach back panel.
Step 2  ¶
  • Slide the back panel towards top of the device and lift away from the device to detach back panel.
Step 3  ¶
Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
Step 3  ¶
  • Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
Step 4  ¶
Slide the speaker towards the bottom of the device to remove. Slide the speaker towards the bottom of the device to remove.
Step 4  ¶
  • Slide the speaker towards the bottom of the device to remove.
