Help
Creative Ziio 7" Motherboard Replacement
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Removal and replacement of the motherboard in the Creative ZiiO 7".
  • Author: Benedict Samoy
  • Time estimate: 20 - 30 minutes
  • Difficulty: Difficult
In this guide, you will be able to remove the motherboard from a creative ZiiO and use a soldering iron while doing so.
Step 1 Motherboard  ¶
Remove the copper plate covering the motherboard by desoldering the ten solder points. The solder point in the bottom right corner is marked but hidden by the soldering iron. The solder point in the bottom right corner is marked but hidden by the soldering iron.
  • Remove the copper plate covering the motherboard by desoldering the ten solder points.
  • The solder point in the bottom right corner is marked but hidden by the soldering iron.
Step 2  ¶
Remove the adhesive tape covering the three wires connected to the motherboard. Desolder the solder points connecting the wires to the motherboard.
Step 2  ¶
  • Remove the adhesive tape covering the three wires connected to the motherboard.
  • Desolder the solder points connecting the wires to the motherboard.
Step 3  ¶
Disconnect the ribbon cable that is attached underneath the copper plate. Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board. Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
Step 3  ¶
  • Disconnect the ribbon cable that is attached underneath the copper plate.
  • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
Step 4  ¶
Remove the four 4mm Philips #00 screws  holding the motherboard to the casing. The copper plate will be removed by now. However, the picture does not show this.
Step 4  ¶
  • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
  • The copper plate will be removed by now. However, the picture does not show this.
Step 5  ¶
Lift up the motherboard. A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
Step 5  ¶
  • Lift up the motherboard.
  • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
  • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
Step 6  ¶
Remove the red and black wires with a soldering iron that are located underneath the motherboard.
Step 6  ¶
  • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
  • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
Step 7  ¶
Remove the old motherboard and dispose of it resposibly.
Step 7  ¶
  • Remove the old motherboard and dispose of it resposibly.
