Help
Sanyo Katana Front Case Replacement
This guide instructs on how to remove the outer front case on the receiver of the device.
  • Author: StephenYH
  • Time estimate: 5 - 10 minutes
  • Difficulty: Easy
Removing the outer front case of the phone will reveal the LCD component of the device. The case can be swapped out with another of a the same or a different color.
Step 1 Front Case  ¶
Use the spudger to pry off the front case from the left and right sides of the device. Once it has popped off, pull the casing apart with fingers. Once it has popped off, pull the casing apart with fingers.
Step 1 Front Case  ¶
  • Use the spudger to pry off the front case from the left and right sides of the device.
  • Once it has popped off, pull the casing apart with fingers.
