Help
Canon PowerShot SD 600 Interior Rear Frame Replacement
Use this repair guide to remove the interior rear frame in a Canon PowerShot SD 600.
  • Author: Krystal Eades
  • Time estimate: 15 - 20 minutes
  • Difficulty: Moderate
This guide will walk you through the process of removing the interior rear frame in a Canon PowerShot SD 600.
Step 1 Interior Rear Frame  ¶
There are six 3mm screws located on the interior frame.
  • There are six 3mm screws located on the interior frame.
  • Remove the screws with the screwdriver.
Step 2  ¶
After the screws are removed gently pull the frame away from the rest of the camera. The interior frame should now be disconnected. The interior frame should now be disconnected.
Step 2  ¶
  • After the screws are removed gently pull the frame away from the rest of the camera.
  • The interior frame should now be disconnected.
