Help
MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
This guide is an internal private guide used as a prereq.
Step 1 Logic Board  ¶
Grab the plastic pull tab secured to the display data cable lock, and rotate it toward the DC-in side of the computer. Pull the display data cable connector straight away from its socket, towards the DC-in side of the computer. Pull the display data cable connector straight away from its socket, towards the DC-in side of the computer.
  • Grab the plastic pull tab secured to the display data cable lock, and rotate it toward the DC-in side of the computer.
  • Pull the display data cable connector straight away from its socket, towards the DC-in side of the computer.
Step 2  ¶
Remove the following two screws securing the display data cable bracket to the upper case: One 7 mm Phillips.
Step 2  ¶
  • Remove the following two screws securing the display data cable bracket to the upper case:
  • One 7 mm Phillips.
  • One 5 mm Phillips.
  • Lift the display data cable bracket out of the upper case.
Step 3  ¶
Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
Step 3  ¶
  • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
Step 4  ¶
In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
Step 4  ¶
  • In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
  • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
  • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
Step 5  ¶
Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board. Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board. Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
Step 5  ¶
  • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
Step 6  ¶
Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable. Use your spudger to slide the keyboard ribbon cable out of its socket. Use your spudger to slide the keyboard ribbon cable out of its socket.
Step 6  ¶
  • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
  • Use your spudger to slide the keyboard ribbon cable out of its socket.
Step 7  ¶
Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
Step 7  ¶
  • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
Step 8  ¶
Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable. Use your spudger to slide the keyboard backlight ribbon cable out of its socket. Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
Step 8  ¶
  • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
  • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
Step 9  ¶
Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
Step 9  ¶
  • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
Step 10  ¶
Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
Step 10  ¶
  • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
Step 11  ¶
Remove the following screws:
Step 11  ¶
  • Remove the following screws:
  • Five 3.1 mm Phillips.
  • Two 3.9 mm Phillips.
  • Two 7 mm Phillips from the DC-in board.
Step 12  ¶
Remove the following Tri-point screws securing the battery to the upper case: One 5.5 mm Tri-point screw.
Step 12  ¶
  • Remove the following Tri-point screws securing the battery to the upper case:
  • One 5.5 mm Tri-point screw.
  • One 13.5 mm Tri-point screw.
  • Lift the battery out of the upper case.
Step 13  ¶
Lift the logic board from its left edge and raise it until the ports clear the side of the upper case. Pull the logic board away from the side of the upper case and remove it, minding the DC-in board that may get caught.
Step 13  ¶
  • Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
  • Pull the logic board away from the side of the upper case and remove it, minding the DC-in board that may get caught.
  • Be careful not to rip out the fragile connector plug of the microphone assembly.
