Help
Installing Mercedes W166 RAV Tool Box
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Member-Contributed Guide
Installation of a Roadside Assistance Vehicle Tool Box
  • Author: Stefan
  • Time estimate: 2 - 3 hours
  • Difficulty: Moderate
Step 1 RAV Tool Box  ¶
1. Vehicle Preparation Remove all loose items from the cargo area. Remove the cargo floor, spare wheel and tool tray.
  • 1. Vehicle Preparation
  • Remove all loose items from the cargo area. Remove the cargo floor, spare wheel and tool tray.
  • Remove rear seats as in WIS instructions (Save seat mounting hardware)
Step 2  ¶
Remove bolt from rear deck sill plate Unclip rear deck sill plate and remove. Unclip rear deck sill plate and remove.
Step 2  ¶
  • Remove bolt from rear deck sill plate
  • Unclip rear deck sill plate and remove.
Step 3  ¶
Remove plastic covers
Step 3  ¶
  • Remove plastic covers
  • Remove Felt liner
Step 4  ¶
Remove side consoles and center support (T30 10 Bolts) Remove side consoles and center support (T30 10 Bolts) Remove side consoles and center support (T30 10 Bolts)
Step 4  ¶
  • Remove side consoles and center support (T30 10 Bolts)
Step 5  ¶
Install and bolt down center support bracket (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers) Pay attention to the pin to align properly NOTE: To service TPMS  control module remove drawers ad service through access door in bottom plate.
Step 5  ¶
  • Install and bolt down center support bracket (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers)
  • Pay attention to the pin to align properly
  • NOTE: To service TPMS control module remove drawers ad service through access door in bottom plate.
Step 6  ¶
2. Installation of Front Box Place box inside vehicle. It fits through the rear doors. This is a 2 person job. Mount front legs on front consoles, tighten loosely (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers). Pay attention not to break off the alignment pin, which will be inside the post after mounting.
Step 6  ¶
  • 2. Installation of Front Box
  • Place box inside vehicle. It fits through the rear doors. This is a 2 person job.
  • Mount front legs on front consoles, tighten loosely (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers). Pay attention not to break off the alignment pin, which will be inside the post after mounting.
  • DO NOT mount the box to the center bracket at this point
Step 7  ¶
3. Installation of the rear plate Install 6 rear support brackets and tighten finger tight
Step 7  ¶
  • 3. Installation of the rear plate
  • Install 6 rear support brackets and tighten finger tight
Step 8  ¶
Set plate on brackets and align, overlapping the base plate of the front box on the center support bracket. Use punch tool to align holes and drop in 2 bolts M8 x 1.25 x 40mm in holes on each side and one bolt M8 x 1.25 x 30 in the center hole. Use punch tool to align holes and drop in 2 bolts M8 x 1.25 x 40mm in holes on each side and one bolt M8 x 1.25 x 30 in the center hole.
Step 8  ¶
  • Set plate on brackets and align, overlapping the base plate of the front box on the center support bracket.
  • Use punch tool to align holes and drop in 2 bolts M8 x 1.25 x 40mm in holes on each side and one bolt M8 x 1.25 x 30 in the center hole.
Step 9  ¶
Secure plate to center support bracket with 2 bolts on the outside and on in the middle, align and finger tighten Secure plate to center support bracket with 2 bolts on the outside and on in the middle, align and finger tighten Secure plate to center support bracket with 2 bolts on the outside and on in the middle, align and finger tighten
Step 9  ¶
  • Secure plate to center support bracket with 2 bolts on the outside and on in the middle, align and finger tighten
Step 10  ¶
Install 3 bolts securing base plate to vehicle frame and 4th bolt securing the tool box rail to the base plate and vehicle frame.
Step 10  ¶
  • Install 3 bolts securing base plate to vehicle frame
  • and 4th bolt securing the tool box rail to the base plate and vehicle frame.
  • Put bolt sizes in
Step 11  ¶
Install and loosely tighten 3 M8 black oxide bolts on each side until L bracket touches the underside of the base plate Install and loosely tighten 3 M8 black oxide bolts on each side until L bracket touches the underside of the base plate
Step 11  ¶
  • Install and loosely tighten 3 M8 black oxide bolts on each side until L bracket touches the underside of the base plate
Step 12  ¶
Fully tighten M8 (20 Nm) Fully tighten M6 (8 Nm)
Step 12  ¶
  • Fully tighten M8 (20 Nm)
  • Fully tighten M6 (8 Nm)
Step 13  ¶
Fully tighten M10 bolts (35 Nm) Fully tighten M10 bolts (35 Nm) Fully tighten M10 bolts (35 Nm)
Step 13  ¶
  • Fully tighten M10 bolts (35 Nm)
Step 14  ¶
4.    Install box Remove drawers and slide box on rail guides, align with bolt holes Install 6 (M12) bolts and fully tighten to 66 Nm
Step 14  ¶
  • 4. Install box
  • Remove drawers and slide box on rail guides, align with bolt holes
  • Install 6 (M12) bolts and fully tighten to 66 Nm
Step 15  ¶
Install drawers. After drawer is installed move rail clip to locked position After drawer is installed move rail clip to locked position
Step 15  ¶
  • Install drawers.
  • After drawer is installed move rail clip to locked position
Step 16  ¶
Fasten seat belt with bolt to floor
Step 16  ¶
  • Fasten seat belt with bolt to floor
