Help
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Rear Display Bezel Replacement
Remove the rear display bezel to access most of your display's internals.
Step 1 Rear Display Bezel  ¶
Image 1/2:
  • Remove the 4.5 mm Phillips screws from the lower left and right corners of the display (two screws total). These screws have a .8 mm thick head.
Step 2  ¶
Image 1/3: Do not insert your spudger between the plastic strip and the rear bezel.
Step 2  ¶
  • Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
  • Do not insert your spudger between the plastic strip and the rear bezel.
  • With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
  • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Step 3  ¶
Image 1/2: Pry the rear bezel away from the front bezel to slightly separate the bottom edge of the rear display bezel.
Step 3  ¶
  • Insert your spudger between the front and rear display bezels at the lower right corner of the display.
  • Pry the rear bezel away from the front bezel to slightly separate the bottom edge of the rear display bezel.
Step 4  ¶
Image 1/2: Twist the spudger to separate the lower edge of the rear display bezel from the clutch cover.
Step 4  ¶
  • Insert the flat end of a spudger into the gap between the rear display bezel and the clutch cover.
  • Twist the spudger to separate the lower edge of the rear display bezel from the clutch cover.
  • Work along the lower edge of the rear bezel until it is evenly separated from the clutch cover.
Step 5  ¶
Image 1/3:
Step 5  ¶
  • Now that the right and bottom edges of the rear bezel are slightly separated from the front bezel, use a spudger to pop the rear bezel off the tabs near the lower right corner of the display.
Step 6  ¶
Image 1/2: Rotate your spudger toward the rear bezel to separate it from the front bezel.
Step 6  ¶
  • Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
  • Rotate your spudger toward the rear bezel to separate it from the front bezel.
  • If necessary, continue separating the left edge of the rear bezel off the tabs on the front display bezel.
Step 7  ¶
Image 1/1: Go here for the guide to continue replacing the screen:  [guide|1287]
Step 7  ¶
