Help
iPad 2 CDMA Camera Bracket Replacement
Replace the camera bracket in your iPad 2 CDMA.
Use this guide to replace the camera bracket in your iPad 2 CDMA.
Parts of this guide were shot with a Wi-Fi model and as such the internals may look slightly different from the cellular model. The procedure is the same for both models except where noted.
Step 1 Camera Bracket  ¶
The camera bracket is attached to the front panel by adhesive. The use of an iOpener to soften the adhesive is highly recommended.
  • The camera bracket is attached to the front panel by adhesive. The use of an iOpener to soften the adhesive is highly recommended.
  • Follow the iOpener heating instructions described in the iOpener heating section at the beginning of this guide.
  • Be careful not to overheat the iOpener during the repair procedure. We recommend waiting at least two minutes before reheating the iOpener.
  • Place the iOpener over the front facing camera on the front edge of the top of the display.
Step 2  ¶
Use the flat end of a spudger to push the camera bracket off the adhesive securing it to the front panel. The camera bracket will move about 2 mm to the right or left depending which way you push the camera bracket.
Step 2  ¶
  • Use the flat end of a spudger to push the camera bracket off the adhesive securing it to the front panel.
  • The camera bracket will move about 2 mm to the right or left depending which way you push the camera bracket.
Step 3  ¶
Lift and remove the camera bracket up off the front panel.
Step 3  ¶
  • Lift and remove the camera bracket up off the front panel.
