Help
OLPC XO-1.5 Screen Replacement
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
This guide will demonstrate how to install the screen of the OLPC XO-1.5 laptop.
  • Author: Andrew Ferrell
  • Time estimate: 20 - 25 minutes
  • Difficulty: Moderate
This guide will show you how to access the screen on your OLPC XO 1.5.
Sections
Tools
Step 1 Screen  ¶
Turn the laptop so it is resting on its bottom. Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop. Rotate the top half of the laptop about 90 degrees.
Step 1 Screen  ¶
  • Turn the laptop so it is resting on its bottom.
  • Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
  • Rotate the top half of the laptop about 90 degrees.
Step 2  ¶
Turn the laptop upside down, so you can see the screws on the bottom of the top half. Remove the two 4mm screws with a Phillips #1 screwdriver.
Step 2  ¶
  • Turn the laptop upside down, so you can see the screws on the bottom of the top half.
  • Remove the two 4mm screws with a Phillips #1 screwdriver.
  • Rotate the top half 180 degrees.
Step 3  ¶
Rotate the top of the laptop 90 degrees, so that it is facing you again.
Step 3  ¶
  • Rotate the top of the laptop 90 degrees, so that it is facing you again.
  • Slide the green pieces off the device. They should come off easily.
Step 4  ¶
Pull down on the white screen cover. It does not require much force. Remove the screen cover. The game pad on the left sometimes falls during this step.
Step 4  ¶
  • Pull down on the white screen cover. It does not require much force.
  • Remove the screen cover.
  • The game pad on the left sometimes falls during this step.
Step 5  ¶
Unscrew the four 7.62mm Phillips #1 screws on either side of the screen. The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
Step 5  ¶
  • Unscrew the four 7.62mm Phillips #1 screws on either side of the screen.
  • The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
  • Move the screen down a little to expose the ribbon cables.
Step 6  ¶
Flip up the tab right under the middle top of the screen. Pull the black ribbon cable out of the socket. Pull the black ribbon cable out of the socket.
Step 6  ¶
  • Flip up the tab right under the middle top of the screen.
  • Pull the black ribbon cable out of the socket.
Step 7  ¶
Flip up the smaller tab under the left side of the screen. Remove the small cable to separate the screen from the rest of the laptop.
Step 7  ¶
  • Flip up the smaller tab under the left side of the screen.
  • Remove the small cable to separate the screen from the rest of the laptop.
  • Gently remove the screen.
