Help
Black and Decker Toast R Oven Knobs Replacement
Remove and replace knobs and/or faceplate on oven.
Before replacing knobs you will have to disassemble oven to take off the knobs and faceplate.
Step 1 Knobs  ¶
Make sure that the toaster is unplugged before you begin.
Step 1 Knobs  ¶
  • Make sure that the toaster is unplugged before you begin.
  • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
Step 2  ¶
Pull down and out to remove side panels from the unit Repeat for the other side.
Step 2  ¶
  • Pull down and out to remove side panels from the unit
  • Repeat for the other side.
Step 3  ¶
Remove the bottom vent.
Step 3  ¶
  • Remove the bottom vent.
  • This should come off fairly easy.
Step 4  ¶
Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
Step 4  ¶
  • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
Step 5  ¶
Remove the crumb tray (bottom metal panel) from the toaster unit.
Step 5  ¶
  • Remove the crumb tray (bottom metal panel) from the toaster unit.
Step 6  ¶
Remove the aluminum strip on the bottom of the unit.
Step 6  ¶
  • Remove the aluminum strip on the bottom of the unit.
Step 7  ¶
Remove knobs by pulling up on them.
Step 7  ¶
  • Remove knobs by pulling up on them.
Step 8  ¶
Unhook the bottom of the display panel from the toaster unit.
Step 8  ¶
  • Unhook the bottom of the display panel from the toaster unit.
  • It will be a little tough to pry off, but don't be afraid to be forceful.
Step 9  ¶
Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
Step 9  ¶
  • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
  • This will also be a little tough to get off, but don't be afraid to be forceful.
