Help
Technique: Shure SM58 XLR Connector Wire Repair
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
This guide will show you how to solder any broken wires back onto the Microphone XLR Connector.
  • Author: nat coll
  • Time estimate: 5 - 10 minutes
  • Difficulty: Moderate
The XLR Connector is the part of the microphone that plugs into the cable which carries the sound to the sound mixer and speakers.
Step 1 Shure SM58 XLR Connector Wire Repair  ¶
If the wire is not exposed from the insulation, strip the broken wire.
  • If the wire is not exposed from the insulation, strip the broken wire.
Step 2  ¶
Bend the wire around the contact point. Pin numbers are located on the outside of the connector.
Step 2  ¶
  • Bend the wire around the contact point. Pin numbers are located on the outside of the connector.
  • Connect the red wire to Pin 3 and the blue wire to Pin 2.
  • Pin 1 should have a single piece of exposed wire connecting it to the metal plate on the top of the connector (the ground plate).
Step 3  ¶
Clamps are helpful for this step.
Step 3  ¶
  • Clamps are helpful for this step.
  • In one hand, hold the solder. In the other hold your soldering iron.
  • Touch both the soldering iron and the solder to the contact point. The solder should melt and create a connection between the wire and the microphone connector.
Step 4  ¶
Remove the solder and then the soldering iron from the contact point.
Step 4  ¶
  • Remove the solder and then the soldering iron from the contact point.
  • If you remove the soldering iron first, the solder may become stuck to the contact point.
  • Let the wire cool for 30 seconds or so.
  • If the wire is not completely connected repeat steps 2 through 5.
Step 5  ¶
To reinstall the XLR connector, follow the Installing Shure SM58 XLR connector guide
Step 5  ¶
