Help
Shure SM58 Collar Replacement
This guide shows you how to dissemble the collar of the microphone. The collar is where the microphone screws together.
  • Author: nat coll
  • Time estimate: 30 seconds
  • Difficulty: Easy
The collar is the place the top and bottom of the microphone screw together. After unscrewing it, you will have access to most of the internal parts of the microphone.
Step 1 Collar  ¶
Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it. Be careful to not pull on the collar or you may rip the wires from the faceplate. Be careful to not pull on the collar or you may rip the wires from the faceplate.
Step 1 Collar  ¶
  • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
  • Be careful to not pull on the collar or you may rip the wires from the faceplate.
