Help
Nook Tablet Back Cover Replacement
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Back case removal guide.
This guide will show you how to remove the back cover revealing the battery. This will allow you to access the inside of the nook tablet and will act as prerequisite for most of the other guides
Step 1 Back Cover  ¶
Flip the Nook over.
Step 1 Back Cover  ¶
  • Flip the Nook over.
Step 2  ¶
Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present. Remove the tape covering the round holes to reveal two T5 Torx screws.
Step 2  ¶
  • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
  • Remove the tape covering the round holes to reveal two T5 Torx screws.
  • Remove the two T5 Torx screws securing the back cover.
Step 3  ¶
Insert the flat end of a spudger between the front panel and the rear assembly. Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
Step 3  ¶
  • Insert the flat end of a spudger between the front panel and the rear assembly.
  • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
  • Use a spudger to lift the the back panel from the rest of the Nook.
Step 4  ¶
Slide the spudger around the edges of the Nook to loosen the back panel. Slide the spudger around the edges of the Nook to loosen the back panel.
Step 4  ¶
  • Slide the spudger around the edges of the Nook to loosen the back panel.
Step 5  ¶
Pull the back panel off the Nook.
Step 5  ¶
  • Pull the back panel off the Nook.
