Help
iBook G3 Clamshell Optical Drive Replacement
  • Author: iRobot
  • Difficulty: Moderate
Upgrade or replace the CD or DVD drive.
Step 1 Optical Drive  ¶
If the optical drive is not open, use a straightened paperclip to open it now.
  • If the optical drive is not open, use a straightened paperclip to open it now.
  • Remove the 5 mm standoff.
Step 2  ¶
Disconnect the optical drive cable from the logic board.
Step 2  ¶
  • Disconnect the optical drive cable from the logic board.
Step 3  ¶
Lift up on the optical drive while sequentially pushing the small plastic tabs one after another toward the screen to free one side of the drive.
Step 3  ¶
  • Lift up on the optical drive while sequentially pushing the small plastic tabs one after another toward the screen to free one side of the drive.
  • Lift up the side of the optical drive you just freed and slide the drive out and away from the screen.
  • When reinstalling the optical drive, be sure that the drive tray is out far enough to slide under the lower casing rim.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
