Help
Google Pixel XL Motherboard Replacement
Remove and replace a broken or malfunctioning motherboard for the Google Pixel XL.
  • Author: Arthur Shi
  • Time estimate: 40 - 45 minutes
  • Difficulty: Moderate
If you're having issues with the overall functionality of your phone and are unable to diagnose the root cause, consider replacing the motherboard of your device.
The Pixel XL’s unreinforced display panel is fragile and is attached to the frame with strong adhesive, making repairs difficult. There is a considerable chance of breaking the display, especially if it already has micro-fractures. Be sure to apply plenty of heat and be extremely careful during the prying stage. v
Step 1 Motherboard  ¶
Use the point of a spudger to pry up and disconnect the battery connector. Bend the battery flex cable slightly so that it will not accidentally touch the motherboard. Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
  • Use the point of a spudger to pry up and disconnect the battery connector.
  • Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
Step 2  ¶
Use the point of a spudger to pry up and disconnect the button strip connector. If the button strip's metal clip falls out during the repair, align the clip and push it back into its groove.
Step 2  ¶
  • Use the point of a spudger to pry up and disconnect the button strip connector.
  • If the button strip's metal clip falls out during the repair, align the clip and push it back into its groove.
Step 3  ¶
Use tweezers to peel up the tape at the top of the interconnect cable. Use tweezers to peel up the tape at the top of the interconnect cable.
Step 3  ¶
  • Use tweezers to peel up the tape at the top of the interconnect cable.
Step 4  ¶
Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard. Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard.
Step 4  ¶
  • Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard.
Step 5  ¶
Use the point of a spudger to disconnect the black antenna cable from the motherboard, near the front facing camera module. Route the antenna cable out of its retaining clip. Route the antenna cable out of its retaining clip.
Step 5  ¶
  • Use the point of a spudger to disconnect the black antenna cable from the motherboard, near the front facing camera module.
  • Route the antenna cable out of its retaining clip.
Step 6  ¶
Use the point of a spudger to pry up and disconnect the white antenna cable from the motherboard, near the rear facing camera module. Route the antenna cable out of its retaining clip.
Step 6  ¶
  • Use the point of a spudger to pry up and disconnect the white antenna cable from the motherboard, near the rear facing camera module.
Step 7  ¶
Remove the two 3 mm T5 screws securing the motherboard to the frame.
Step 7  ¶
  • Remove the two 3 mm T5 screws securing the motherboard to the frame.
  • During reinstallation, be sure that both camera modules and the headphone jack module are seated properly in their sockets before screwing down the motherboard.
Step 8  ¶
Use the point of a spudger to pry up and loosen the front facing camera module from its socket. Use the point of a spudger to pry up and loosen the front facing camera module from its socket. Use the point of a spudger to pry up and loosen the front facing camera module from its socket.
Step 8  ¶
  • Use the point of a spudger to pry up and loosen the front facing camera module from its socket.
Step 9  ¶
Insert the point of a spudger into the headphone jack port and pry upwards to loosen the port from its socket. Insert the point of a spudger into the headphone jack port and pry upwards to loosen the port from its socket.
Step 9  ¶
  • Insert the point of a spudger into the headphone jack port and pry upwards to loosen the port from its socket.
Step 10  ¶
Be sure that you have ejected the SIM card tray before performing this step. Use the flat end of a spudger to pry the bottom edge of the motherboard up slightly, loosening it from its recess.
Step 10  ¶
  • Be sure that you have ejected the SIM card tray before performing this step.
  • Use the flat end of a spudger to pry the bottom edge of the motherboard up slightly, loosening it from its recess.
  • Do not try to remove the motherboard yet. It is still connected by a flex cable.
Step 11  ¶
Locate the fingerprint sensor cable attached to the underside of the motherboard, near the bottom edge. Use the point of a spudger to pry and release the fingerprint sensor cable from its socket.
Step 11  ¶
  • Locate the fingerprint sensor cable attached to the underside of the motherboard, near the bottom edge.
  • Use the point of a spudger to pry and release the fingerprint sensor cable from its socket.
  • Peel the cable away from the motherboard.
Step 12  ¶
Hold the motherboard by the corners and maneuver it out of its recess, being careful not to snag any cables. During reinstallation, be sure to route both antenna cables underneath the motherboard edges, and direct them through the cable notches.
Step 12  ¶
