Help
Lenovo G50-80 80E5 Removing top panel Replacement
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
Remove top panel to access internal components
  • Author: Victor
  • Time estimate: 45 minutes
  • Difficulty: Difficult
Step 1 Removing top panel  ¶
Remove wifi wires by lifting up
  • Remove wifi wires by lifting up
Step 2  ¶
locate power and monitor cable on bottom side next to fan
Step 2  ¶
  • locate power and monitor cable on bottom side next to fan
Step 3  ¶
remove power cable with tweezers by gently pullying
Step 3  ¶
  • remove power cable with tweezers by gently pullying
Step 4  ¶
remove monitor cable by gently pulling on tab straight up
Step 4  ¶
  • remove monitor cable by gently pulling on tab straight up
Step 5  ¶
Monitor and power cable disconnected
Step 5  ¶
  • Monitor and power cable disconnected
Step 6  ¶
Disconnect the fan wires from the motherboard by lifting upwards
Step 6  ¶
  • Disconnect the fan wires from the motherboard by lifting upwards
Step 7  ¶
Locate the 3 screws holding fan in place Remove 3 screws fan should lift out of place
Step 7  ¶
  • Locate the 3 screws holding fan in place
  • Remove 3 screws
  • fan should lift out of place
Step 8  ¶
lift clip to remove ribbon cable for think pad.
Step 8  ¶
  • lift clip to remove ribbon cable for think pad.
Step 9  ¶
lift clip to remove power button ribbon cable. lift clip to remove power button ribbon cable.
Step 9  ¶
  • lift clip to remove power button ribbon cable.
Step 10  ¶
Begin by locating screws on bottom panel
Step 10  ¶
  • Begin by locating screws on bottom panel
Step 11  ¶
Remove screws using a 001 phillips screw driver.
Step 11  ¶
  • Remove screws using a 001 phillips screw driver.
Step 12  ¶
Once screws are removed,  begin by gently prying up in one corner using a spudge Continue to center and then around to opposite side. once all sides have been pried open, lift top half off
Step 12  ¶
  • Once screws are removed, begin by gently prying up in one corner using a spudge
  • Continue to center and then around to opposite side.
  • once all sides have been pried open, lift top half off
Step 13  ¶
Top covered removed
Step 13  ¶
  • Top covered removed
