Help
HP Envy dv7t-7200 RAM Replacement
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
Use this guide to replace faulty RAM on your HP Envy dv7t-7200 if your laptop is running slow or you would like more memory.
  • Author: Krystal
  • Time estimate: 5 - 9 minutes
  • Difficulty: Moderate
Sections
Tools
Step 1 RAM  ¶
Press down and away from the ram cards on the tabs surrounding the ram cards. Press down and away from the ram cards on the tabs surrounding the ram cards.
Step 1 RAM  ¶
  • Press down and away from the ram cards on the tabs surrounding the ram cards.
Step 2  ¶
The first ram card will pop up, and now you will slide it out of its slot. The first ram card will pop up, and now you will slide it out of its slot.
Step 2  ¶
  • The first ram card will pop up, and now you will slide it out of its slot.
Step 3  ¶
Repeat this process for the second ram card. Repeat this process for the second ram card. Repeat this process for the second ram card.
Step 3  ¶
  • Repeat this process for the second ram card.
