Help
Lenovo G50-80 80E5 Power Button Replacement
This guide will instruct you on how to remove and replace the power button on the Lenovo G50-80 80E5 laptop.
This guide will show you how to unscrew and remove the power board button from your laptop.
Step 1 Power Button  ¶
At this point in disassembly, there will be one #00x5.5 mm screw securing the power button board in place. Take your screwdriver and remove the screw.
  • At this point in disassembly, there will be one #00x5.5 mm screw securing the power button board in place.
  • Take your screwdriver and remove the screw.
Step 2  ¶
Take your tweezers and grip the power button board. Using tweezers, lift power button board up and out. The cable wire for the power button board should be disconnected at this point and the piece should lift out without any extra work needed. Using tweezers, lift power button board up and out. The cable wire for the power button board should be disconnected at this point and the piece should lift out without any extra work needed.
Step 2  ¶
  • Take your tweezers and grip the power button board.
  • Using tweezers, lift power button board up and out. The cable wire for the power button board should be disconnected at this point and the piece should lift out without any extra work needed.
