Fix Your Stuff
Right to Repair
Store
Help
Editing Step 22 —
Notice: You are editing a prerequisite guide. Any changes you make will affect the guide that includes this step.
Step Type:
Drag to rearrange
Return to step 5 of this guide and ensure the thick portions of adhesive are adequately separated from the display assembly. If they are, continue with this step. Otherwise, slice the adhesive to break it up until the display assembly is freed.
The display cables in this iPad are shorter than some users may be comfortable with. Read the following warnings before proceeding:
Do not pivot the display about the lower edge. The display cables do not have enough slack to allow for this and will tear if you do not slide the display towards the front-facing camera as you lift.
The display cables will tear if you raise the display more than 80º.
Lift up the upper edge of the display and slide it towards the front-facing camera to access the iPads internal components.
