Help
Editing Step 15 —
Notice: You are now editing a prerequisite to the guide you were just viewing. Any changes you make will affect all 21 guides that include this step.
Step Type:
Drag to rearrange
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
If necessary, use the flat end of a spudger to separate the microphone from the upper case.
Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
