Fix Your Stuff
Right to Repair
Store
Help
Editing Step 10 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 5 guides that include this step.
Step Type:
Drag to rearrange
During the glass removal process, the AirPort & iSight data cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your AirPort & iSight data cable is still connected to the camera board, skip this step.
If your objective is to remove the camera board, skip this step as reconnecting the AirPort & iSight data cable is not necessary.
To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the AirPort & iSight data cable ZIF socket.
Use the tip of a spudger to flip up the ZIF cable retainer on the AirPort & iSight data cable socket.
Insert the AirPort & iSight data cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
Reapply the piece of tape covering the AirPort & iSight data cable socket.
