Fix Your Stuff
Right to Repair
Store
Help
Editing Step 1 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 5 guides that include this step.
Step Type:
Drag to rearrange
In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
