Help
Google Pixel XL Display Assembly Replacement
Editing Step 9 —
Notice: You are now editing a prerequisite to the guide you were just viewing. Any changes you make will affect all 8 guides that include this step.
Step Type:
Drag to rearrange
Use the point of a spudger to pry up and disconnect the display cable from its connector.
To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
