You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This is a guide to replacing the Back Cover on the Zune Flash 2nd Generation.
Parts
No parts specified.
  1. Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure. If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images. You should hear a 'click' as the clip detaches from the device.
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Shop Now
    PC Laptop Batteries
    Shop Now
  4. Remove the two screws shown using a small Tri-Wing screwdriver.
    • Remove the two screws shown using a small Tri-Wing screwdriver.
    • You will need to use a very small Tri-Wing screwdriver to ensure that you do not strip the screws.
  5. Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device. Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device. Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  6. Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside. Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside. Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
ybahman
118 Reputation
4 Guides authored
Cal Poly, Team 9-20, Regan Fall 2009 Member of Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 3,274
