Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Follow this guide to replace the Fingerprint Scanner for the ZTE Blade Spark. To get to this step please see ZTE Blade Spark Disassembly Guide
Parts
No parts specified.
  1. Remove the Fingerprint Scanner:
    • Remove the Fingerprint Scanner:
    • Gently lift to disconnect the scanner's power connector from the device main frame.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Now that the scanner and device back panel is detached from the back of the device , push the scanner through from the front side of the back cover.
    • Now that the scanner and device back panel is detached from the back of the device , push the scanner through from the front side of the back cover.
    • Once you have done so, set aside.
To reassemble your device, follow the instructions on the ZTE Blade Spark Disassembly guide in reverse order.
Hung Vu
608 Reputation
5 Guides authored
Gateway, Team S1-G6, Johnson Spring 2018 Member of Gateway, Team S1-G6, Johnson Spring 2018
GCC-JOHNSON-S18S1G6
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 80
