Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Follow this guide to replace the Battery for the ZTE Blade Spark. To get to this step please see ZTE Blade Spark Disassembly Guide
Parts
No parts specified.
  1. Remove the battery: Disconnect the battery's power connector from the device mainframe.
    • Remove the battery:
    • Disconnect the battery's power connector from the device mainframe.
    • Lift the battery from its slot and set aside.
  2. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  3. Install replacement battery:
    • Install replacement battery:
    • Attach the replacement battery by connecting its corresponding power connector to the device mainframe.
    • Then, set the replacement battery properly in place as originally found.
To reassemble your device, follow the instructions on the ZTE Blade Spark Disassembly guide in reverse order.
Hung Vu
608 Reputation
5 Guides authored
Gateway, Team S1-G6, Johnson Spring 2018 Member of Gateway, Team S1-G6, Johnson Spring 2018
GCC-JOHNSON-S18S1G6
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 298
