ZD-N Plus Wireless Controller Repair D-Pad Replacement
  1. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Back Panel: step 1, image 1 of 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller Repair D-Pad Replacement: step 2, image 1 of 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement: step 2, image 2 of 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Battery: step 3, image 1 of 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller Repair D-Pad Replacement: step 4, image 1 of 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement: step 4, image 2 of 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller Repair D-Pad Replacement: step 5, image 1 of 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement: step 5, image 2 of 2
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Rumble Motor: step 6, image 1 of 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement, Rumble Motor: step 6, image 2 of 2
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
  7. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Motherboard: step 7, image 1 of 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement, Motherboard: step 7, image 2 of 2
    • Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
  8. ZD-N Plus Wireless Controller Repair D-Pad Replacement: step 8, image 1 of 1
    • Lift the motherboard out of the controller.
  9. ZD-N Plus Wireless Controller Repair D-Pad Replacement, D-Pad: step 9, image 1 of 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement, D-Pad: step 9, image 2 of 2
    • Simply remove the plastic piece of the directional pad. It is not glued in so it should come out easily.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 154
