YCCTEAM YCC-SW4001 Battery Replacement
  1. YCCTEAM YCC-SW4001 Battery Replacement, Front Case: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
  2. YCCTEAM YCC-SW4001 Battery Replacement: step 2, image 1 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 2, image 2 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 2, image 3 of 3
    • Use an opening pick to pry the back cover off of the controller.
  3. YCCTEAM YCC-SW4001 Battery Replacement: step 3, image 1 of 1
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
  4. YCCTEAM YCC-SW4001 Battery Replacement: step 4, image 1 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 4, image 2 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 4, image 3 of 3
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
  5. YCCTEAM YCC-SW4001 Battery Replacement: step 5, image 1 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 5, image 2 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 5, image 3 of 3
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
  6. YCCTEAM YCC-SW4001 Battery Replacement: step 6, image 1 of 2 YCCTEAM YCC-SW4001 Battery Replacement: step 6, image 2 of 2
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
  7. YCCTEAM YCC-SW4001 Battery Replacement: step 7, image 1 of 1
    • Remove the front case.
  8. YCCTEAM YCC-SW4001 Battery Replacement, Battery: step 8, image 1 of 3 YCCTEAM YCC-SW4001 Battery Replacement, Battery: step 8, image 2 of 3 YCCTEAM YCC-SW4001 Battery Replacement, Battery: step 8, image 3 of 3
    • Remove the two joystick covers by gripping them and pulling them straight upward with moderate force.
  9. YCCTEAM YCC-SW4001 Battery Replacement: step 9, image 1 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 9, image 2 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 9, image 3 of 3
    • Use tweezers to grip the white plastic battery connector. Lift it directly it up and out of its socket.
    • Do not pull on the wires.
    • When replacing the battery, press the plug down into the socket until it snaps into place.
  10. YCCTEAM YCC-SW4001 Battery Replacement: step 10, image 1 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 10, image 2 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 10, image 3 of 3
    • Use a Phillips screwdriver to remove the three 7.5 mm screws that secure the motherboard.
    • Remove the player LEDs from the motherboard.
  11. YCCTEAM YCC-SW4001 Battery Replacement: step 11, image 1 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 11, image 2 of 3 YCCTEAM YCC-SW4001 Battery Replacement: step 11, image 3 of 3
    • Gently lift the motherboard up and out of the controller and set it directly between the grips.
    • Take care not to damage the rumble motor connections.
  12. YCCTEAM YCC-SW4001 Battery Replacement: step 12, image 1 of 1
    • Use a spudger to gently lever the battery out of the controller.
    • The battery is attached with adhesive, so gently sever the adhesive around the entirety of the battery as you pry.
    • Take care not to puncture or bend the battery.
    • If your new battery does not come with adhesive, apply new adhesive to secure the battery.
David Adaway
537 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 296
