Xiaomi Yi Back Panel Replacement
  1. Xiaomi Yi Back Panel Replacement, Battery: step 1, image 1 of 2 Xiaomi Yi Back Panel Replacement, Battery: step 1, image 2 of 2
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Back Panel Replacement: step 2, image 1 of 3 Xiaomi Yi Back Panel Replacement: step 2, image 2 of 3 Xiaomi Yi Back Panel Replacement: step 2, image 3 of 3
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Back Panel Replacement, Front Panel: step 3, image 1 of 2 Xiaomi Yi Back Panel Replacement, Front Panel: step 3, image 2 of 2
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Back Panel Replacement: step 4, image 1 of 3 Xiaomi Yi Back Panel Replacement: step 4, image 2 of 3 Xiaomi Yi Back Panel Replacement: step 4, image 3 of 3
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Back Panel Replacement, Back Panel: step 5, image 1 of 2 Xiaomi Yi Back Panel Replacement, Back Panel: step 5, image 2 of 2
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Back Panel Replacement: step 6, image 1 of 3 Xiaomi Yi Back Panel Replacement: step 6, image 2 of 3 Xiaomi Yi Back Panel Replacement: step 6, image 3 of 3
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Back Panel Replacement: step 7, image 1 of 2 Xiaomi Yi Back Panel Replacement: step 7, image 2 of 2
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
10 other people completed this guide.
Karol Gonzalez
379 Reputation
1 Guide authored
USF Tampa, Team 15-5, Blackwell Fall 2015 Member of USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Members
10 Guides authored
2 Comments
Where can I buy back panel for Xiaomi Yi?
matulek - Reply
Where can i buy the back panel replacement ?
Roland Meilleur - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 3,550
