Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement
  1. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement, The motherboard: step 1, image 1 of 1
    • Before you begin, switch off your phone.
    • Heat your phone to about 195 degrees Fahrenheit (90 C).
  2. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 2, image 1 of 1
    • Lift the back cover to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
  3. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 3, image 1 of 1
    • Start sliding the opening pick from the lower left corner along the side of the device to cut the adhesive
    • Leave the opening pick in the side to prevent the adhesive from resealing.
  4. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 4, image 1 of 1
    • Lift the cover open like a book, but be careful to make sure you do not damage the flex cable while itā€™s still connected.
  5. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 5, image 1 of 2 Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 5, image 2 of 2
    • Using a screwdriver (1.5 mm ), unscrew 4 screw and remove the bracket holding the connector.
  6. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 6, image 1 of 1
    • Disconnect the connector to avoid a possible short circuit during disassembly.
    • Disconnect connectors and remove the inter-board cable.
  7. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 7, image 1 of 3 Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 7, image 2 of 3 Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 7, image 3 of 3
    • Using a screwdriver (1.5 mm), unscrew the 7 screws.
    • Remove the cover.
  8. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 8, image 1 of 1
    • Pry up on the connector and remove the fingerprint sensor cable.
  9. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 9, image 1 of 1
    • Disconnect the connector on PCB, and remove the front facing (selfie) camera.
  10. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 10, image 1 of 1
    • Disconnect the connectors on the PCB.
  11. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: step 11, image 1 of 1
    • Pull off and remove the PCB.
17 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Remphone.ru
630 Reputation
1 Guide authored
One Comment
Give Me Your Phone Number..
The Comedy King - Reply
Past 24 Hours: 11
Past 7 Days: 64
Past 30 Days: 229
All Time: 10,916
