Xiaomi Mi 9T Pro Display Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Xiaomi Mi 9T Pro Display Replacement, Remove SIM card: step 1, image 1 of 1
    • Remove SIM card
  2. Xiaomi Mi 9T Pro Display Replacement, Remove the back cover: step 2, image 1 of 3 Xiaomi Mi 9T Pro Display Replacement, Remove the back cover: step 2, image 2 of 3 Xiaomi Mi 9T Pro Display Replacement, Remove the back cover: step 2, image 3 of 3
    • Heat the back cover and use plastic tools to carefully pry it off.
    • Attention: There is also adhesive around the camera
  3. Xiaomi Mi 9T Pro Display Replacement, Remove the upper inner cover: step 3, image 1 of 3 Xiaomi Mi 9T Pro Display Replacement, Remove the upper inner cover: step 3, image 2 of 3 Xiaomi Mi 9T Pro Display Replacement, Remove the upper inner cover: step 3, image 3 of 3
    • Remove the screws and take out the component.
  4. Xiaomi Mi 9T Pro Display Replacement, Disconnect the battery connection: step 4, image 1 of 2 Xiaomi Mi 9T Pro Display Replacement, Disconnect the battery connection: step 4, image 2 of 2
    • Carefully disconnect the connection to the battery
  5. Xiaomi Mi 9T Pro Display Replacement, Removing the lower inner cover: step 5, image 1 of 3 Xiaomi Mi 9T Pro Display Replacement, Removing the lower inner cover: step 5, image 2 of 3 Xiaomi Mi 9T Pro Display Replacement, Removing the lower inner cover: step 5, image 3 of 3
    • Remove the screws holding down the lower inner cover and carefully remove it.
  6. Xiaomi Mi 9T Pro Display Replacement, Disconnect connecting cable: step 6, image 1 of 3 Xiaomi Mi 9T Pro Display Replacement, Disconnect connecting cable: step 6, image 2 of 3 Xiaomi Mi 9T Pro Display Replacement, Disconnect connecting cable: step 6, image 3 of 3
    • First, carefully disconnect the lower connector.
    • Attention: The silver foil is adhesive foil and will be needed again later, so heat it up beforehand and loosen it carefully.
    • The adapter comes out from under the adhesive foil.
    • Then, carefully loosen the upper connector and put the cable aside.
  7. Xiaomi Mi 9T Pro Display Replacement, Heat and loosen screen cable: step 7, image 1 of 1
    • Heat and loosen the screen cable.
  8. Xiaomi Mi 9T Pro Display Replacement, Removing the display: step 8, image 1 of 3 Xiaomi Mi 9T Pro Display Replacement, Removing the display: step 8, image 2 of 3 Xiaomi Mi 9T Pro Display Replacement, Removing the display: step 8, image 3 of 3
    • Heat the edges of the display and carefully remove it.
    • Attention: Carefully remove the screen cable.
  9. Xiaomi Mi 9T Pro Display Replacement, Installing the new display: step 9, image 1 of 3 Xiaomi Mi 9T Pro Display Replacement, Installing the new display: step 9, image 2 of 3 Xiaomi Mi 9T Pro Display Replacement, Installing the new display: step 9, image 3 of 3
    • Remove the plastic cover on the rear side of the new display.
    • Apply the adhesive to the edge of the display.
    • Connect the display cable to new display.
    • Press the display down.
  10. Xiaomi Mi 9T Pro Display Replacement, Reconnecting display cable with connecting cable: step 10, image 1 of 3 Xiaomi Mi 9T Pro Display Replacement, Reconnecting display cable with connecting cable: step 10, image 2 of 3 Xiaomi Mi 9T Pro Display Replacement, Reconnecting display cable with connecting cable: step 10, image 3 of 3
    • Reconnect the display cable with the connecting cable.
    • Use adhesive film to reattach.
    • Reattach the upper part of the connecting cable.
  11. Xiaomi Mi 9T Pro Display Replacement, Reinstalling and tightening lower inner cover: step 11, image 1 of 2 Xiaomi Mi 9T Pro Display Replacement, Reinstalling and tightening lower inner cover: step 11, image 2 of 2
    • Reinstall and tighten the lower inner cover.
  12. Xiaomi Mi 9T Pro Display Replacement, Reinstall upper inner cover: step 12, image 1 of 2 Xiaomi Mi 9T Pro Display Replacement, Reinstall upper inner cover: step 12, image 2 of 2
    • Reinstall lower cover and screw tight.
  13. Xiaomi Mi 9T Pro Display Replacement, Reattach back panel: step 13, image 1 of 2 Xiaomi Mi 9T Pro Display Replacement, Reattach back panel: step 13, image 2 of 2
    • Apply glue to the edge of the back plate.
    • Reattach the back plate.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Stefan K
469 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 969
