Xbox 360 Racing Wheel - Fix variable resistance pot
View statistics:
Past 24 Hours:
6
Past 7 Days:
21
Past 30 Days:
92
All Time:
981
Comments: 6
6 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide is for Xbox 360 Wireless Racing Wheel that experiences erratic steering behavior, whereby the wheel is not moving consistently with the input, or jumping all over the place. This is easiest to view the problem in a Windows PC with the wireless receiver, via the gamepad properties where you can compare your wheel motion to what the computer sees. If you see the output jumping all over the place, this is an indication that the variable resistance pot (potentiometer) has gotten dirty or is broken.
Parts
Tools
    1. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the base: step 1, image 1 of 1
      • Remove 8 screws from the base (two are covered by the sticker), using a TX10 security screwdriver (i.e. with the security hole at the top)
      Ask FixBot
    2. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the steering wheel back panel: step 2, image 1 of 1
      • Remove the additional 8 screws from the back of the wheel assembly, again, using the TX10 security screwdriver.
      Ask FixBot
    1. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the potentiometer: step 3, image 1 of 3 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the potentiometer: step 3, image 2 of 3 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the potentiometer: step 3, image 3 of 3
      • Identify the small beige panel with the pot on it. Place the steering wheel in the middle position and note the pot orientation (flat area of white guide will be towards to left.
      • Disconnect the plug.
      • Using a TX10 screwdriver, remove the panel, and place it on your workbench.
      Ask FixBot
    2. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove Pot Top Cover: step 4, image 1 of 3 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove Pot Top Cover: step 4, image 2 of 3 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove Pot Top Cover: step 4, image 3 of 3
      • Potentiometer is a 10 k-ohm, and it is difficult to find a replacement, but it might simply need to be cleaned.
      • Note that the rivets may impede the cover from coming up, so use the side that has the most clearance from the rivet. Then using two jewelers screwdrivers, carefully lift at one corner while carefully bending the tab on that side. Twist just enough to allow the cover of the pot to get past the tab.
      • Once the pot is clear of the tab, use a small pair of pliers to gently extract the top portion of the pot.
      • Place the cover of the pot upside-down on your workbench
      Ask FixBot
    3. Xbox 360 Racing Wheel - Fix variable resistance pot, Use Isopropyl alcohol to clean the pot material: step 5, image 1 of 2 Xbox 360 Racing Wheel - Fix variable resistance pot, Use Isopropyl alcohol to clean the pot material: step 5, image 2 of 2
      • Using a cotton swab moistened with alcohol, gently clean the pot top cover traces. Notice the grey residue on the swab.
      Ask FixBot
    4. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the pot wiper and clean: step 6, image 1 of 2 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the pot wiper and clean: step 6, image 2 of 2
      • Remove the wiper from the pot body. Note: the wiper is extremely small and thin, so be extremely gentle.
      • Once on the workbench, use a clean swab moistened with alcohol, and lightly clean the wiper contacts, applying very little pressure so as not to change the shape of the wipers.
      Ask FixBot
    5. Xbox 360 Racing Wheel - Fix variable resistance pot, Re-install pot wiper and pot cover: step 7, image 1 of 3 Xbox 360 Racing Wheel - Fix variable resistance pot, Re-install pot wiper and pot cover: step 7, image 2 of 3 Xbox 360 Racing Wheel - Fix variable resistance pot, Re-install pot wiper and pot cover: step 7, image 3 of 3
      • Using a screwdriver down the middle of the board for alignment, drop the wiper back into the body of the pot.
      • Align the pot cover into the grooves at the back (the side opposite from the connector), the gently press down until it clicks into the tabs. Note that the metal extensions of the pot cover interfered with the rivets slightly, and a screwdriver was used to get past the rivets.
      Ask FixBot
      • Re-install the pot board with the 2 TX10 screws.
      • Reconnect the connector.
      • Re-assemble the bottom cover and base.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Do not overtorque the screws as they are into a plastic casing and will strip easily.
Michel_K17
618 Reputation
3 Guides authored
6 Guide Comments
where can you find replacement pots as the one on my wheel has gone
doubl99 - Reply Share
like the traces on mine are clean but too worn to actually work anymore
I did a search on the internet (by picture and by text) and I was unable to find an exact replacement. I see two options: pull a working pot from another used wheel, or source a generic 10.5 kilo-ohm* pot that is similar, and mechanical bind (glue?) the shaft into the potentiometer's hole. Note: 10.5 kilo-ohm is what I measured at full deflection, so most likely, it is a 10.0 kilo-ohm pot.
Michel_K17 - Reply Share
Hermano, al mío le pasa que todo el tiempo se quiere auto-centrar cuando juego si detecta baches, grava y choques y el force feedback reacciona, pero el volante se pone duro desde que se sincroniza con el Xbox 360. Se puede jugar así pero el constante forcejeo del motor quiere dónde centrar cuando estoy girando el volante lo hace incómodo y cansado. Crees que se deba a un problema con el potenciómetro? O sabrás que pueda ser?
Lupe Martínez - Reply Share
Bro, the issue with mine is that it constantly tries to self-center whenever the game detects bumps, gravel, or collisions and the force feedback kicks in; the wheel gets stiff the moment it syncs with the Xbox 360. It’s playable, but the motor’s constant struggle to return to center while I’m turning the wheel makes it uncomfortable and tiring. Do you think it’s a problem with the potentiometer? Or do you have any idea what it might be?
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 92
All Time: 981
