Introduction
Following this guide involves opening the Xbox 360 E and is somewhat more involved than replacing other parts of the Xbox.
Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
Firmly grip the green Wi-Fi card and pull it out of the Xbox.
On that wifi card there is a little port that you can plug and old router antena into. Any idea what its called?
Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
Missing some steps here…. Where are the clips holding the sides together? To go straight from “Remove bottom cover” to “Device is apart” is a bit… lacking.
Yes, Aksel Barnes is correct. There are missing pictures and steps showing the removal of the plastic exterior from the metal section.
another "manual" missing the hardest steps
Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
Lift the bottom body slightly away from the core at a 45 degree angle.
Use your fingers to unplug the blue ribbon cable from the CD drive.
Note: The ribbon cable connected to the CD drive can be in the color red (as it was on my board). Just make sure the other end is connected to the motherboard to be sure.
Como destrava a gaveta do cd
Lift the front end of the CD drive and take it out.
Just note that you will have to swap the PCB inside the disc drive. If you do not go through with this the game will not start.
You do also require some soldering skills as the wires for the motor and sensor for the disc tray are soldered to the PSB.
22 other people completed this guide.
11 Comments
screws are actually C1- C5 one is incorrectly labelled - C7 = C1 also in step 8.5 there are 3 clips holding back edge of bottom cover to top one. one on each end and one just to right of I/O area. can get 2 of them with a spudger (ends) and the middle one with a isesamo.
Several steps missing between 8 and 9
Like remove wifi adaptor.
There is some consistency errors in this guide. Step 9 seems to blast ahead beyond where we should be at this point of the guide.
Yeah, most definitely it jumps from removing the side grills to have completely disassembled the entire console case...
All the videos I watch tell me to take the drive apart and use the old motherboard on the new drive, so it's the same old motherboard. But mine is broke so can I just use the same motherboard from the new drive?
No must change the board over or it will not work.Gregory Lansberry.
Did you not mention the fact that the drives won’t work unless programmed?
I have had the need to replace the cd assembly on a few 360 e-models. The problem I run into occasionally is the new cd assembly will sometimes only play music discs. I'm not sure if there is a software lock on the assembly or not as installing a 2nd new drive fixes the problem. Are some 360 drive assemblies not compatible with certain mobo revisions? Also, once you get the sides off, a very long screwdriver does the trick on the clips to get it open.
