Introduction
Use this guide to remove the gray plastic lower vent from your Xbox 360.
Tool used on this step:Xbox 360 Opening Tool$4.99
Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
Pry the front edge of the bottom vent away from the faceplate.
68 other people completed this guide.
You can avoid this step by pulling the front cover off. Just make sure you don't break the springs for the USB bay area.
Repair Doctor - Reply
Hello, thank you ifix for this guide, I followed this guide, I got stuck at some point but I resolved it. Also I want to share this resource: Step by Step guide to fix Xbox 360 errors it helped me go through all the things associated with Xbox 360 and the troubleshooting of errors. Hope this can also help you all.
Christopher Sage - Reply
