Introduction
This guide will involve the replacement of the motor that drives the X-Street SRT Viper. Reinstalling the motor will require you to re-solder the wires back on. This guide is slightly more difficult than the other guides. Follow and reach each step carefully.
Click here to purchase a replacement motor. Replacement Motor
Remove the four 3 mm screws from the bottom panel using a 3 mm Philips #1 screwdriver.
White connection removal. Begin by removing the two 6mm Phillips #2 screws that hold down the white connection from the underside panel to the rear wheel and motor assembly.
Detach the black wire that is attached to the outer shell of the motor itself. Use a soldering iron or wire cutters—not scissors as shown in photo.
Using these desoldering techniques, remove the solder.
Pull apart the motor housing with care and clip off the wires that are soldered on to the motor.
Re-Solder the two wires back on to the motor when replaced. Refer to this How To Solder guide for more information.
