You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Use this guide to replace the outer case on your Nintendo Wii U GamePad.
  1. Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover. Lift up and remove the battery cover.
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it. Pull upwards from the bottom of the battery to release it. Pull upwards from the bottom of the battery to release it.
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Shop Now
    PC Laptop Batteries
    Shop Now
  4. Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers. Lift up the back plate. The back plate is still connected by a cable to the motherboard.
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  5. Unplug the connector that connects the back plate to the motherboard. Remove the back plate.
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
Kim Arre
3,411 Reputation
8 Guides authored
Cal Poly, Team 17-20, Forte Winter 2013 Member of Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Members
19 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 52
All Time: 9,774
