Introduction
查看 iPad Wi-Fi Repair Manual以获得全套维修指南!
昨天,我们抢先发布了一些照片,那时我们可以编写的2197|FCC的测试照片]。但是,请注意:你所看到的是一个预制单元,而这里的照片来自零售版的。
想要跟上硬件世界的步伐吗?点击
我们的
Error
Example:
[Namespace:Which Entity|What you want people to see on the page]
Current text:
[[主题:iPad]]
YouTube[链接| http://www.youtube.com/watch?v=F52osxxZv...|
更新4/5:我们与ChipWorks合作的拆解图片
关注我们的官方微博:iFixit官网资讯
显示器有一个出厂标记:Honeywell#5280371
它看起来相当松散,主要是因为所有的3G通信模块都没有。
3.75V, 24.8瓦特小时的电池提供持续10小时的使用时间。相比之下,iPhone 3GS有4.51瓦特小时的电池,而MacBook Air有40瓦特小时
USB电源适配器已专门为iPad而增强。由Foxlink技术有限公司生产的10W单元,编号为A1357 W010A051。
802.11n WiFi/蓝牙卡集成到尾插排线上。
躲在下方芯片:
Broadcom BCM4329XKUBG 802.11n WiFi +蓝牙2.1 + EDR和FM。
环境光传感器和照相机卡在一个小隔间里。
我们怀疑这个隔间是为环境光传感器设计的,而在这里安装摄像头的传言过于狂热。这个布局看起来非常类似于MacBook Pro 13“Unibody的摄像头的布局。
Special thanks to these translators:
74%
These translators are helping us fix the world! Want to contribute?
Start translating ›
8 Comments
i used your post here -http://cafe.naver.com/disassemblemachine problem is hyunil0327@naver.com
Is it possible to replace the A4 with a better processor or add RAM?
No, it is not possible. You cannot upgrade any parts on this, or later generation iPads, since the boards are all completely custom designed for each generation, and not compatible. Also as in most laptops, the size constraints mean that the processor was not intended to be replaceable, as is clear when you look at step 15.
joshadow -
can I change the logic board?
Yes, you can. The system memory will be entirely different, though. iPad Wi-Fi Logic Board Replacement
