Introduction
Go to step 1 ↓Use this guide to remove the 2-in-1 agitator, the spring-loaded plate cap, and the wash plate impeller from a Whirlpool top-load washer (model WTW5057LW0). This design uses a twist-lock agitator and a spring-loaded cap system, so it comes apart differently than systems with an obvious center fastener.
Step 1 Prepare for disassembly
Unplug the washer from the wall outlet.
Open the lid, and make sure the tub is empty and dry enough for good grip.
Step 2 Remove the 2-in-1 agitator
Lift up on the agitator handle.
Turn the agitator counterclockwise about one eighth of a turn to dislodge it from the base.
Pull straight up to lift the agitator out of the tub.
Step 3 Identify the spring-loaded cap system
Look at the exposed center area to find the plate-cap system under the agitator.
Step 4 Remove the plate cap
Use a trampoline spring tool or another hooked tool to grab the plate cap at its slot.
Pull straight up to release the plate-cap assembly from the wash plate.
Step 5 Free a stuck plate cap
Check the cap's retaining fingers if the cap will not release easily.
Insert thin slotted screwdrivers into the holes in the cap.
Flex the pieces outward to help the fingers release, then lift the cap out.
Step 6 Remove the wash plate screw
Locate the wash-plate screw in the center under where the cap was removed.
Use a 7/16 socket to turn the screw counterclockwise until it comes out.
Use an impact driver or a socket wrench with an extension if needed to loosen the screw.
Step 7 Remove the wash plate and inspect
Lift the wash-plate impeller off the gear case once the screw is removed.
Inspect the gear-case splines and the underside of the wash plate for damage or stripped splines.
Step 8 Reinstall the wash plate and screw
Align the wash plate with the gear-case splines and press it down until it seats.
Apply blue thread locker to the wash-plate screw by holding it upright and coating the threads.
Reinstall the screw using the same method you used to remove it, then tighten it securely.
Step 9 Reinstall the plate cap and agitator
Align the plate-cap tabs with the wash plate so it only fits in its keyed orientation, then press until it snaps into place.
Set the 2-in-1 agitator into position on its base.
Repair didn't go as planned? Ask our Answers community for help.
