Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel
    1. Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Open Liner Compartment: step 1, image 1 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Open Liner Compartment: step 1, image 2 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Open Liner Compartment: step 1, image 3 of 3
      • Starting with an empty duffel, open the main zipper compartment.
      • Locate the zipper in the liner and open. This will expose the inside of the plastic wheel housing.
      • If the wheel and axle are missing, a nut and washer may be loose inside this liner compartment. Try to locate the washer and nut to reuse.
      • Patagonia Repair Tech Tip: To increase visibility, use an extra light source like a flashlight or headlamp.
      Ask FixBot
    2. Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove Broken Wheel & Axle: step 2, image 1 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove Broken Wheel & Axle: step 2, image 2 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Remove Broken Wheel & Axle: step 2, image 3 of 3
      • If the damaged wheel and axle are still attached, locate the axle nut inside the liner compartment and hold it in place with the adjustable wrench.
      • If there is excess foam and lining fabric blocking access, see Step 5 and then come back.
      • From the outside, turn the axle using the 4mm Allen wrench to free the wheel and axle from the plastic wheel housing. Save the washer and nut to reuse.
      • Righty tighty, lefty loosey!
      • Test the other wheel for functionality and remove if it is broken.
      Ask FixBot
    3. Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Assess Damage of Wheel Parts: step 3, image 1 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Assess Damage of Wheel Parts: step 3, image 2 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Assess Damage of Wheel Parts: step 3, image 3 of 3
      • Assess both wheels on the luggage:
      • Damaged Tread – If the wheel has a worn rubber tread or a flat spot (reference image #2), the wheel must be replaced, skip to Step 5.
      • Damaged Axle – If the original wheel is in working shape, but the axle is bent (reference image #3), continue to Step 4.
      • Missing Wheel – If both the wheel and axle are missing, skip to Step 5.
      • Responsibly discard any unusable pieces.
      Ask FixBot
    4. Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Salvage Working Wheel from Bent Axle: step 4, image 1 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Salvage Working Wheel from Bent Axle: step 4, image 2 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Salvage Working Wheel from Bent Axle: step 4, image 3 of 3
      • If the original wheel is in working shape, but the axle is bent, you can often free the wheel by cutting the axle off.
      • Using bolt cutters, cut the axle as close to wheel as possible.
      • Use safety glasses.
      • If the cut axle remains stuck inside the wheel, elevate the wheel with a sturdy surface, and tap the cut end of the axle using a flat head screwdriver and a hammer until the axle is driven out.
      • What did I just say about safety glasses?
      Ask FixBot
    5. Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Prepare the Inside of the Plastic Housing: step 5, image 1 of 2 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Prepare the Inside of the Plastic Housing: step 5, image 2 of 2
      • There is often excess foam and lining fabric blocking access to the back of the plastic housing.
      • It is okay to cut away this excess using an X-Acto blade.
      • Use extreme caution to avoid cutting yourself or other parts of the duffel.
      Ask FixBot
    6. Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Reassemble Wheel & Axle: step 6, image 1 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Reassemble Wheel & Axle: step 6, image 2 of 3 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Reassemble Wheel & Axle: step 6, image 3 of 3
      • Place a new or salvaged wheel onto a new axle and insert the axle into the plastic wheel housing.
      • Inside the plastic wheel housing, place a washer and a nut onto the axle and finger-turn until attached.
      • Then use the adjustable wrench or needle nose vise grip to keep the nut in-place and tighten the axle from the outside using the 4mm Allen wrench.
      • Make sure the locking nylon ring on the nut engages on the axle. This prevents the nut from loosening during use.
      Ask FixBot
      • Do not overtighten the nut.
      • Check the wheel function by spinning the wheel or rolling the luggage on the floor.
      • A perfectly-tightened Black Hole wheel spins freely for about 1-2 seconds.
      Ask FixBot
    7. Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Close Lining Compartment: step 8, image 1 of 2 Wheel Replacement on a Patagonia Black Hole® Wheeled Duffel, Close Lining Compartment: step 8, image 2 of 2
      • Check the liner compartment to make sure no tools have been left behind.
      • Close the zipper to the liner compartment.
      Ask FixBot
Finish Line
2 other people completed this guide.
Zach Mueller
1,810 Reputation
9 Guides authored
Patagonia Member of Patagonia
Community
9 Members
384 Guides authored
3 Guide Comments
Thanks! Saved me a few emails and phone calls✨
Cullen Cole - Reply Share
Where can I buy new wheels?
Lindsey F. Marshall, DMD - Reply Share
If you reach out to Patagonia customer service, they’ll send you some for free!
Clara Redwood - Reply Share
Past 24 Hours: 10
Past 7 Days: 87
Past 30 Days: 505
All Time: 10,794
