Introduction
If the device is not changing speed it may be because of a broken speed adjuster.
  1. Unscrew the locking sleeve.
    • Unscrew the locking sleeve.
  2. Remove the hanging clip.
    • Remove the hanging clip.
    • Unscrew the six 8mm PH2 screws.
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
    • Identify the screws.
      • Unscrew the two 3mm phillips PH2.
      • Don't forget to put them appart from the ones unscrewed before.
      • Phillips PH2
      • Flathead 2.5mm
    • Remove the place boar carefully.
    • Pull out the power cable connectors.
    • Pull out the cord sleve for the new cable replacement.
    • Remove the connected wiring from the circuit board.
    • Remove the single 4mm screw retaining the circuit board.
    • Gently pry the circuit board from the back piece.
Dominick Chavez
119 Reputation
1 Guide authored
USF Tampa, Team 12-1, Eyestone Spring 2016 Member of USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 223
