Wahl Lithium Ion 5537C Blade Replacement
  1. Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: step 1, image 1 of 2 Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: step 1, image 2 of 2
    • Take out the batteries by pulling off the cover from the back and once done put the cover back on.
  2. Wahl Lithium Ion 5537C Blade Replacement: step 2, image 1 of 3 Wahl Lithium Ion 5537C Blade Replacement: step 2, image 2 of 3 Wahl Lithium Ion 5537C Blade Replacement: step 2, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the two screws on the blade and place them in the container.
    • Detach the blade from the body of the shaver and also remove the blade supporting mounts.
  3. Wahl Lithium Ion 5537C Blade Replacement: step 3, image 1 of 3 Wahl Lithium Ion 5537C Blade Replacement: step 3, image 2 of 3 Wahl Lithium Ion 5537C Blade Replacement: step 3, image 3 of 3
    • Grab the replacement new blade and before mounting the support mount clean it with the cleaning brush to remove any dirt.
    • Place the supporting mount back to the new blade making sure it is properly attached.
  4. Wahl Lithium Ion 5537C Blade Replacement: step 4, image 1 of 3 Wahl Lithium Ion 5537C Blade Replacement: step 4, image 2 of 3 Wahl Lithium Ion 5537C Blade Replacement: step 4, image 3 of 3
    • Place the blade with mount attached to the trimmer such that the screw holes are visible through
    • Grab on the blade hard and torque both screws one by one.
    • Check if the blade is attached tightly to the trimmer.
    • Insert the batteries inside the trimmer and start using!
Osman Saeed
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 42
All Time: 1,053
