Tools
Parts
No parts specified.
Remove nine 12mm Phillips screws from the upper back panel.
Remove three 12mm Phillips screws inset under the back panel.
You're viewing a previously published version of this guide. View latest version
No parts specified.
As soon as the screws are removed, the panel will fall freely.
When replacing the twelve 12mm Phillips screws, do not tighten the fasteners until all twelve screws have been loosely fitted back onto the cooler. This will ensure the flimsy metal casing will not warp.
Remove two 7mm Hex Nuts.
Clearance is minimal and these screws are very tight. You will likely need a socket wrench to avoid stripping.
If the white plastic components stick, pry them apart with a metal spudger. Don't pull on the power cord to get plastic pieces to separate.
Remove power cable from motherboard.
Pinch cable connector to release it from the motherboard, then pull.
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 606
