Introduction
The speaker is attached to the motherboard. Thus, after removing the motherboard, the speaker can be replaced.
  1. Hold handset with one hand with the keypad facing downward.
    • Hold handset with one hand with the keypad facing downward.
  2. Place thumb on the indentation located at the top of the battery cover.
    • Place thumb on the indentation located at the top of the battery cover.
    • Press down and gently slide the cover off the back of the handset.
    • Set the battery cover aside.
    • Use thumb and index finger to gently pull the wired connection from the handset.
    • Remove the battery.
    • Using a screwdriver, remove the two 10.0mm Philips #0 screws at the bottom corners of the rear casing of the handset.
    • Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone.
    • Using a screwdriver, remove the two 10.0mm Philips #0 round head screws at the top corners of the handset motherboard.
    • Remove the handset motherboard.
    • Hold the motherboard display side up.
    • Using the black spudger, pry into the upper right corner of the speakers casing.
    • Using the index fingers, gently push on the white tabs that extrude beyond the motherboard.
    • feed the speaker through the slot above the display,where the wires of the speaker run through.
    • Use the portable soldering iron to melt the glue which holds the speaker's wires to the motherboard.
Sheckeem Daley
573 Reputation
5 Guides authored
USF Tampa, Team 16-4, Blackwell Winter 2016 Member of USF Tampa, Team 16-4, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 255
