Introduction
Replace the keypad on your VTech CS6114.
Hold handset with one hand with the keypad facing downward.
  • Hold handset with one hand with the keypad facing downward.
Place thumb on the indentation located at the top of the battery cover. Press down and gently slide the cover off  the back of the handset. Set the battery cover aside.
  • Place thumb on the indentation located at the top of the battery cover.
  • Press down and gently slide the cover off the back of the handset.
  • Set the battery cover aside.
Use thumb and index finger to gently pull the wired connection from the handset. Remove the battery. Remove the battery.
  • Use thumb and index finger to gently pull the wired connection from the handset.
  • Remove the battery.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Using a screwdriver, remove the two 10.0mm Philips #0 screws at the bottom corners of the rear casing of the handset.
  • Using a screwdriver, remove the two 10.0mm Philips #0 screws at the bottom corners of the rear casing of the handset.
Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone. Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone. Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone.
  • Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone.
Using a screwdriver, remove the two 10.0mm Philips #0 round head screws at the top corners of the handset motherboard. Remove the handset motherboard.
  • Using a screwdriver, remove the two 10.0mm Philips #0 round head screws at the top corners of the handset motherboard.
  • Remove the handset motherboard.
Holding the front casing of the handset, gently push up on the menu key Remove the keypad from the interior of the front casing using a peeling motion.
  • Holding the front casing of the handset, gently push up on the menu key
  • Remove the keypad from the interior of the front casing using a peeling motion.
Sheckeem Daley
573 Reputation
5 Guides authored
USF Tampa, Team 16-4, Blackwell Winter 2016 Member of USF Tampa, Team 16-4, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G4
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 114
