Introduction
The handset motherboard has the display screen and speaker attached. We will be replacing the motherboard with these pieces still attached.
  1. Hold handset with one hand with the keypad facing downward.
    • Hold handset with one hand with the keypad facing downward.
  2. Place thumb on the indentation located at the top of the battery cover.
    • Place thumb on the indentation located at the top of the battery cover.
    • Press down and gently slide the cover off the back of the handset.
    • Set the battery cover aside.
    • Use thumb and index finger to gently pull the wired connection from the handset.
    • Remove the battery.
    • Using a screwdriver, remove the two 10.0mm Philips #0 screws at the bottom corners of the rear casing of the handset.
    • Separate the rear casing from the front by running the black spudger along the crevice on the outer edge of the phone.
    • Using a screwdriver, remove the two 10.0mm Philips #0 round head screws at the top corners of the handset motherboard.
    • Remove the handset motherboard.
Sheckeem Daley
573 Reputation
5 Guides authored
USF Tampa, Team 16-4, Blackwell Winter 2016 Member of USF Tampa, Team 16-4, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 304
